F52912 fault in siemens sinamics V90 drive
F52912 fault in siemens sinamics V90 drive indicates a Negative torque limitation value error. This means the parameter setting for negative torque limit was incorrectly set to a value greater than zero.
One of negative torque limitation values (P29051) becomes greater than 0.
  • Configure all of negative torque limitation values (P29051) not greater than 0.
