F52980 fault in Siemens V70 Drive
F52980 fault in Siemens V70 Drive indicates the Absolute encoder motor has changed. This means the drive detects a different motor ID than the one it was originally commissioned with, prompting an automatic reconfiguration.
Cause: The servo motor with absolute encoder is changed. Actual motor ID is different from commissioned motor ID.
Remedy: The servo motor will be automatically configured after the acknowledgement of this fault.
