F606 fault in WEG CFW900 Drive indicates Power Monitor Communication is Lost. This means the main control board lost its data link with the internal power monitoring module.
Communication fault between AUI and PMON.
- Defect on the inverter internal circuits.
- Electromagnetic interference above the level the inverter withstands.
- Power board turned off.
Verify internal power board status. Ensure proper connection cables are secure and grounding pathways are clear of noise interference.
