F7085 fault in siemens sinamics V90 drive indicates Open-loop/closed-loop control parameters changed. This means the drive automatically adjusted your control parameters because they exceeded hardware limits or were incompatible with the current hardware features.
Open-loop/closed-loop control parameters have had to be changed for the following reasons:
- As a result of other parameters, they have exceeded the dynamic limits.
- They cannot be used due to the fact that the hardware detected not having certain features.
It is not necessary to change the parameters as they have already been correctly limited.
