F7815 fault in siemens sinamics V90 drive
F7815 fault in siemens sinamics V90 drive indicates the Power unit has been changed. This means the control unit recognizes that it is connected to a different physical power module than the one previously saved in its configuration.
The code number of the actual power unit does not match the saved number.
Connect the original power unit and power up the Control Unit again (POWER ON).
