F7901 fault in Siemens V70 Drive
F7901 fault in Siemens V70 Drive indicates Motor overspeed. This means the actual motor speed exceeded the maximum safe speed limit configured in the drive parameters.
Cause: The maximum permissible speed has been exceeded.
Remedy: Check and correct the maximum speed (p1082).
