F7995 fault in siemens sinamics V90 drive indicates a Motor identification failure. This means the drive could not successfully perform its initial pole position identification, typically because the motor was not fully stopped before being energized.
For incremental motor, needs pole position identification when first SON. If motor already in run (i.e. by external force) position identification may failure.
Stop motor before SON.
