Siemens 6RA70 DC Drive
2
864
Jun 13, 2022 10:08 am
Cause : Converter cooling faulty (active in all operating states) comes when the heat sink temperature is higher than the permissible value (depending on the MLFB).
- The monitoring function is activated 6s after the electronics supply is connected.
The heat sink temperature is higher than the permissible value (depending on the MLFB).
(The current heat sink temperature is indicated at parameter r013 and on connector K050)
