F008 fault in siemens 6RA70 DC Drive
Cause : Line frequency less than the minimum line frequency acc. to parameter P363 comes when line frequency less than the minimum line frequency for longer than set in parameter P086.
  • This fault message is activated if the line frequency is less than the minimum line frequency (for longer than the “restart time” set in parameter P086).
  • Up to software version 1.7 the threshold for activation of the fault message (minimum line frequency) is 45Hz.
  • Frequency of the armature supply < minimum line frequency
  • Frequency of the field supply < minimum line frequency
  • Line frequency less than the minimum line frequency for longer than set in parameter P086 (if >0)
Cause : Line frequency less than the minimum line frequency acc. to parameter P363 (active in operating states of o5).
1 Frequency of the armature supply < minimum line frequency
2 Frequency of the field supply < minimum line frequency
4 Line frequency less than the minimum line frequency for longer than set in parameter P086 (if >0)
