F029 fault in siemens 6RA70 DC Drive
How can resolve problem F029 fault in siemens 6RA70 DC Drive ?
Cause : Motor overtemperature (active in all operating states)
Select via P493=2 or 3 (temperature sensor at terminals 22 / 23) or P494=2 or 3 (temperature sensor at terminals 204 / 205)
When parameter P490.01=1 (KTY84 at terminals 22 / 23)
or P490.02=1 (KTY84 at terminals 204 / 205):
The fault message is activated if the motor temperature reaches or exceeds the value set in parameter P492.
When parameter P490.01=2, 3, 4 or 5 (PTC thermistor at terminals 22 / 23)
or P490.02=2, 3, 4
or 5 (PTC thermistor at terminals 204/ 205):
The fault message is activated if the motor temperature reaches or exceeds the response value of the selected PTC thermistor.
Fault value:
1 Fault activation through temperature sensor at terminals 22 / 23
2 Fault activation through temperature sensor at terminals 204 / 205
Click2Electro
Get free chat support...
🟢 Online
