F042 fault in siemens 6RA70 DC Drive
How can resolve problem F042 fault in siemens 6RA70 DC Drive ?
Cause : Tachometer fault (active in operating states of – –, I, II)
If the check result is incorrect for 4 times in succession, the fault message is activated.
The monitoring function is effective only if the armature current is > 2% of the converter rated DC current set in r072.002.
Possible fault causes
Open circuit in tachometer or pulse encoder cable.
Tachometer of pulse encoder cable incorrectly connected.
Pulse encoder supply has failed.
Polarity for actual speed value (P743) is incorrectly set.
Armature circuit data (P110 und P111) are incorrectly set (execute current controller optimization run).
Tachometer or pulse encoder defective
Pulse encoder supply voltage is incorrectly set (P140)
The field polarity is not reversed by the external hardware when the field is reversed.
Open circuit in tachometer or pulse encoder cable -
- i002 Actual speed value (K0179) in case of fault
- i003 Actual EMF value (K0287) in case of fault
2 Polarity of tachometer or pulse encoder is incorrect
