F080 fault in siemens 6RA70 DC Drive
How can resolve problem F080 fault in siemens 6RA70 DC Drive ?
Cause : Error in initialization of a CB/TB board
Possible causes for fault values 1 and 6:
CB/TB board is defective
CB/TB board is not installed correctly
CB/TB board is taking too long to run up (e.g. due to very complex TB configuration)
Fault value (r949 index 001):                r047 index 002 to 016:
1. The "Heartbeat counter“ of the CB/TB has not started to count within 20 s
i015 Code number of board:
1. TB or 1 st CB ,
2. 2 nd CB
2. The product version of the installed CT/TB board is not compatible with the SIMOREG 6RA70 converter
i002 Code number of slot containing incompatible board:
2 Slot D
3 Slot E
4 Slot F
5 Slot G
6 CB when configuration includes TB
5. Parameters P918, U711 to U721 are not correctly set or not accepted after a change by means of U710 = 0 setting. (The meanings of these parameters are defined in the manual for the relevant CB board, see also function diagrams, Section 8, Sheets Z110 and Z111)
1. TB or 1st CB
2. 2 nd CB
6. The initialization run for a CB/TB board has not been completed within 40 s
1. TB or 1st CB
2. 2 nd CB
