Siemens 6RA80 DC Drive
6
Sep 21, 2024 4:57 am
A01482 alarm in siemens 6RA80 DC Drive indicate that the Sensor Module not inserted. This means the topology comparison has detected a Sensor Module that is missing in the actual topology with respect to the
target topology.
- Insert the components involved at the right connection (correct the actual topology).
- Adapt the project/parameterization in the commissioning software (correct the target topology).
- Check the 24 V supply voltage.
- Check DRIVE-CLiQ cables for interruption and contact problems.
- Check that the component is working properly.
