F07511 fault in siemens 6RA80 DC Drive
F07511 fault in siemens 6RA80 DC Drive indicate that the Encoder used a multiple number of times. This means each encoder may only be assigned to one drive and within a drive must - in each drive data set - either always be encoder 1, always encoder 2 or always encoder 3. This unique assignment has been violated.
  • Correct the double use of a component number using the two parameters coded in the fault value.
