ABB ACS150-03E-01A2-4 drive
ABB ACS150-03E-01A2-4 Drive - take smooth performance to the next level with the wide power range and functionality of ACS150. The drives are easy to select and provide a range of built-in features as standard including PID control, brake chopper, fixed keypad and speed control potentiometer.
An optional Flash-Drop drive configuration tool makes configuring un-powered drives quick and easy. The ABB micro drives can be conveniently tuned to your business needs with precise speed control and simple integration. Add compact efficiency, convenient global service and expertise, and you have everything you need to add big benefits to your small motors.
Best drive for general purpose application with in-build potentiometer. Easy to operate and simple programming process. Drive comes with five digital input, one analog input & one relay output.
Input Suppy Voltage and phase 3-phase, 200 to 240 V ± 10%
Motor Control Method Scalar Control U/f
Overload Capability at Heavy duty use 150% for 1 minute every 10 minutes
Brake Resistor Value 70 ohm/0.37 KW
Supported Motor Types Induction Motor
Output Power Pn (kW/HP) 0.37 kW/ 0.5 HP
Frame Size and Dimensions(HXWXD) in mm R0 (239x70x142 mm)
Digital Inputs 5 DI
Analog Input 1 AI
Relay Output 1 RO
