abb acs150 drive parameter settings
The parameter settings for an ABB ACS150 drive can vary depending on your specific application and requirements. However, here are some common parameter settings that you may need to configure:
  1. Motor Data: Parameters related to the motor connected to the drive, such as motor rated voltage, rated current, rated frequency, and motor type.
  2. Control Mode: Select the control mode of the drive, such as V/Hz control, vector control, or sensorless vector control.
  3. Acceleration/Deceleration Times: Set the acceleration and deceleration times to control the speed at which the motor ramps up or down.
  4. Maximum/Minimum Frequency: Define the maximum and minimum frequencies at which the motor operates.
  5. Current Limiting: Set the maximum current limit to protect the motor from overload conditions.
  6. Voltage Boost: Enable or disable voltage boost to compensate for voltage drops during acceleration.
  7. Braking: Configure braking settings if using a braking resistor or other braking methods.
  8. Fault Handling: Define how the drive responds to various fault conditions, such as whether to trip immediately or attempt a restart.
  9. Control Inputs/Outputs: Configure digital and analog inputs and outputs for control and monitoring purposes.
  10. Communication: Set up communication parameters if connecting the drive to a PLC or other control system, such as baud rate and communication protocol.
  11. Parameter Lock: Optionally, lock certain parameters to prevent unauthorized changes.
  12. Display Settings: Adjust settings related to the drive's display, such as brightness and language.
  13. Fault Log: View or clear the fault log to monitor and troubleshoot any issues that may arise.
These are just some examples of common parameter settings for an ACS150 drive. The specific parameters and their values will depend on your application and the requirements of your motor control system.
Below list show ABB ACS150 drive parameters:
Macro
9902 1 ABB Standard
  2 3-wire
  3 Alternate
  4 Motor Pot
  5 Hand/auto
  6 PID Control
Motor Data
9905 …. V Motor voltage
9906 ….A Motor current
9907 ….Hz Motor Frequency
9908 ….rpm Motor rpm
9909 ….KW Motor power
Limit
2007 ….Hz Min freq.
2008 ….HZ Max. freq.
ACC/DCC Time
2202 ….s Acc time
2203 ….s Dcc time
Actual Signal
107 DC Vol.
120 AI
160 DI
Start Command
1001 8 Keypad in loc
  4 3-wire
  9 Start forward start rev.
Jog Selection
1010 ….(DI) Select DI 1-5
1208 ….Hz Jog frequency
1201 0 Constant speed disable
Constant speed Disable
Refrence Selection
1103 0 Keypad
  1 AI
  2 Potentiometer
  5 DI3 inc DI4 dec
  6 DI3 inc DI4dec (store speed)
Min/Max Ref
1104 ….Hz Min. ref
1105 ….Hz Max. ref
Analog Input
1301 …. % Min AI
1302 …. % Max AI
Relay Output
1401 1 Ready
  2 Run
  3 Fault -1
Run Enable
1601 0 Not selected
Parameter Lock
1602 0 Locked
  1 Open
Pass Code
1603 ….(358)
Local Lock
1606 0 Not selected
  7 ON
Parameter Save
1607 1 Saved
Max Output Current
2003 ….A Max output current
Brake Chopper Function
2005 0 Disable Overvoltage Function
  1 Enable
2102 1 Coast
  2 Ramp
Start Inhibit 0 Off
  1 on
Emergenct Stop
2109 0 1-5 DI
Switching Frequency
2606 4 Hz
  8 Hz
  12 Hz
  16 Hz
External Fault
3003 0 0-5 DI
Motor Thermal Protection
3005 0 Not Select
  1 Fault
  2 Alarm
Drive Display
3401 …… Actual value
