abb acs150 parameter list
The parameter list for an ABB ACS150 drive can be quite extensive and may vary depending on the specific model and firmware version of the drive. However, here is a list of some common parameters found in the ACS150 drive:
Parameters in simple view
Macro
9902 1 ABB Standard
  2 3-wire
  3 Alternate
  4 Motor Pot
  5 Hand/auto
  6 PID Control
Motor Data
9905 …. V Motor voltage
9906 ….A Motor current
9907 ….Hz Motor Frequency
9908 ….rpm Motor rpm
9909 ….KW Motor power
Limit
2007 ….Hz Min freq.
2008 ….HZ Max. freq.
ACC/DCC Time
2202 ….s Acc time
2203 ….s Dcc time
Actual Signal
107 DC Vol.
120 AI
160 DI
Start Command
1001 8 Keypad in loc
  4 3-wire
  9 Start forward start rev.
Jog Selection
1010 ….(DI) Select DI 1-5
1208 ….Hz Jog frequency
1201 0 Constant speed disable
Constant speed Disable
Refrence Selection
1103 0 Keypad
  1 AI
  2 Potentiometer
  5 DI3 inc DI4 dec
  6 DI3 inc DI4dec (store speed)
Min/Max Ref
1104 ….Hz Min. ref
1105 ….Hz Max. ref
Analog Input
1301 …. % Min AI
1302 …. % Max AI
Relay Output
1401 1 Ready
  2 Run
  3 Fault -1
Run Enable
1601 0 Not selected
Parameter Lock
1602 0 Locked
  1 Open
Pass Code
1603 ….(358)
Local Lock
1606 0 Not selected
  7 ON
Parameter Save
1607 1 Saved
Max Output Current
2003 ….A Max output current
Brake Chopper Function
2005 0 Disable Overvoltage Function
  1 Enable
2102 1 Coast
  2 Ramp
Start Inhibit 0 Off
  1 on
Emergenct Stop
2109 0 1-5 DI
Switching Frequency
2606 4 Hz
  8 Hz
  12 Hz
  16 Hz
External Fault
3003 0 0-5 DI
Motor Thermal Protection
3005 0 Not Select
  1 Fault
  2 Alarm
Drive Display
3401 …… Actual value
