ABB ACS180 Drive
673
Jul 14, 2023 6:52 am
Cause : Adaptive program file incompatible or corrupted - comes when adaptive program has faulted due to program corrupted or block non-existent. Check aux code for more information :
- 000A - Program corrupted or block non-existent : Restore the template program or download the program to the drive.
- 000C - Required block input missing : Check the inputs of the block.
- 000E - Program corrupted or block non-existent : Restore the template program or download the program to the drive.
- 0011 - Program too large : Remove blocks until the error stops.
- 0012 - Program is empty. Correct the program and download it to the drive.
- 001C - A non-existing parameter or block is used in the parameter : Edit the program to correct the parameter reference, or use an existing block.
- 001E - Output to parameter failed because the parameter was write-protected : Check the parameter reference in the program. Check for other sources affecting the target parameter.
- 0023 - Program file incompatible with current firmware version : Adapt the program to current block library and firmware version
- 0024 - Program file incompatible with current firmware version: Adapt the program to current block library and firmware version.
Â
