ABB ACS310 Drive
1,381
Jun 20, 2024 5:40 am
Cause : MOTOR TEMPERATURE comes when motor temperature is too high due to excessive load, insufficient motor power, inadequate cooling or incorrect start-up data. This means the motor connected to the drive is likely experiencing overheating.
The A2010 alarm code on your ABB ACS310 drive indicates a MOTOR TEMP issue. This means the motor's temperature is exceeding its safe operating limit.
- Check motor ratings, load and cooling.
- Check start-up data.
- Check fault function parameters.
