ABB ACS310 Drive
349
Jun 20, 2024 5:51 am
Cause : OUTLET HIGH comes when pressure at pump/fan outlet too high. The "OUTLET HIGH" alarm on an ABB ACS310 drive typically indicates a problem with the input signal or a parameter related to the inlet, such as low input voltage, pressure, or flow rate, depending on the specific application the drive is being used for.
- Check piping for blocks.
- See parameter group 44 PUMP PROTECTION.
