ABB ACS310 Drive
1,564
Feb 26, 2024 9:18 am
The parameter list for an ABB ACS310 drive can be quite extensive and may vary depending on the specific model and firmware version of the drive. However, here is a list of some common parameters found in the ACS310 drive:
Motor Data | |||
Macro | 9902 | 1 | ABB Standard |
2 | 3-wire | ||
3 | alternate | ||
4 | motor pot | ||
5 | hand/auto | ||
6 | PID control | ||
7 | PFC control | ||
15 | SPFC Control | ||
Motor Voltage | 9905 | …… | V |
Motor Current | 9906 | ……. | A |
Motor Frequency | 9907 | ……. | Hz |
Motor Speed (rpm) | 9908 | ……. | rpm |
Motor Power KW | 9909 | ……. | KW |
Limits | |||
Minimum Frequency | 2007 | ……. | Hz |
Maximum Frequency | 2008 | ……. | Hz |
ACC Time | 2202 | ……. s | Acc time 1 |
DEC Time | 2203 | ……. s | Dcc Time 1 |
2105 | ……. s | Acc time 2 | |
2106 | ……. s | Dcc Time 2 | |
Start command | |||
1001 | 4 | 3-wire | |
8 | keypad | ||
9 | SF SR | ||
10 | Comm | ||
Refrence | |||
1103 | 0 | Keypad | |
1 | AI | ||
5 | DI3 inc DI4 dec(reset after stop) | ||
6 | DI3 inc DI4 dec(not reset after stop) | ||
8 | Comm | ||
21 | Keypad | ||
Min/Max ref | |||
1104 | ….Hz | Min ref. | |
1105 | ….Hz | Max ref | |
Constant speed disable | |||
1201 | 0 | Disable | |
1202 | ….Hz | Constant speed 1 | |
1203 | ….Hz | Constant speed 2 | |
1204 | ….Hz | Constant speed 3 | |
Analog Input | |||
1301 | ….% | Min AI | |
1302 | ….% | Max AI | |
Relay Output | |||
1401 | 1 | Ready | |
2 | Run | ||
3 | Fault -1 | ||
Analog Output | |||
1501 | Select in group 1 | ||
1502 | Content Min. | ||
1503 | Content max | ||
1504 | Min AO | ||
1505 | Max AO | ||
Run Enable | |||
1601 | 0 | Run enable (not selected) | |
Parameter lock | |||
1602 | 0 | Locked | |
1 | Open | ||
Pass code | |||
1603 | 358 | ||
Fault Reset | |||
1604 | 0 | 1…5 Select DI | |
Local Lock | |||
1606 | 0 | Not selected | |
7 | Lock | ||
Parameter Save | |||
1607 | 1 | Saved | |
Parameter View | |||
1611 | 3 | Long view | |
Digital output | |||
1805 | Select from group 1 | ||
Maximum output current | |||
2003 | ….A | Set max output current | |
Start Inhibit | |||
2108 | 0 | off | |
1 | on | ||
Emergency Stop | |||
2109 | Select DI 1-5 | ||
Switching Freq | |||
2606 | 4KHz | ||
8 | |||
12 | |||
16 | |||
External Fault | |||
3003 | 0 | not selected | |
Motor Thermal Protection | |||
3005 | 0 | Disable | |
1 | Fault | ||
Display Parameter | |||
3401 | Select from group 1 | ||
Communication | |||
9802 | 1 | STD Modbus | |
5302 | ….. | Station ID | |
5303 | 9.6 | Baud rate | |
5304 | 0 | 8 none 1 |
