ABB ACS310 Drive
974
Jun 20, 2024 9:18 am
Cause : SHORT CIRCUIT comes when short circuit in motor cable or motor. This means there's an abnormally low resistance path detected within the drive circuit, causing a high current flow that can damage the drive or connected equipment.
The F0004 code in your ABB ACS310 drive signifies a short circuit fault. This indicates that an abnormally low resistance path has formed between the DC bus terminals within the drive, potentially causing high currents and overheating.
- Check motor and motor cable.
