ABB ACS310 Drive
579
Jun 20, 2024 9:35 am
Cause : AI2 LOSS comes when analog input AI2 signal has fallen below limit defined by parameter 3022 AI2 FAULT LIMIT.
The F0008 code you're referring to is a generic fault code for loss of an analog input signal This indicates that the drive isn't receiving a valid signal from a specific analog input terminal.
- Check fault function parameter settings.
- Check for proper analog control signal levels.
- Check connections.
