ABB ACS310 Drive
1,016
Jun 20, 2024 9:37 am
Cause : MOT OVERTEMP comes when motor temperature is too high (or appears to be too high) due to excessive load, insufficient motor power, inadequate cooling or incorrect start-up data.
The F0009 code in your ABB ACS310 drive indicates a motor overtemperature fault. This means the temperature of the motor connected to the drive has exceeded its safe operating limit.
- Check motor ratings, load and cooling.
- Check start-up data.
- Check fault function parameters.
- Check value of fault limit.
- Check that actual number of sensors corresponds to value set by parameter 3501 SENSOR TYPE.
- Let motor cool down.
- Ensure proper motor cooling: Check cooling fan, clean cooling surfaces, etc.
