F0010 fault in ABB ACS310 drive
Cause : PANEL LOSS comes when control panel selected as active control location for drive has ceased communicating.
The F0010 code in your ABB ACS310 drive indicates a fault related to the control panel. This indicates that the drive is no longer receiving communication or signals from the control panel it's connected to.
  1. Check panel connection.
  2. Check fault function parameters.
  3. Check control panel connector.
  4. Refit control panel in mounting platform.
  5. If drive is in external control mode (REM) and is set to accept start/stop, direction commands or references through control panel: Check group 10 START/STOP/DIR and 11 REFERENCE SELECT settings.
