F0035 fault in ABB ACS310 drive
Cause : OUTPUT WIRING comes when ncorrect input power and motor cable connection like input power cable is connected to drive motor connection). The fault can be erroneously declared if the drive is faulty or the input power is a delta grounded system and the motor cable capacitance is large
The F0035 code in your ABB ACS310 drive indicates an output wiring fault. This means the drive has detected an issue with the connection between the drive and the motor it's controlling.
  • Check input power connections.
