abb acs355 factory reset parameter
10.1 K Views
abb acs355 factory reset parameter - enter the parameter 9902=1 and then enter, the drive will reset to the original default.
Solution : If you want to factory reset ABB ACS355 drive  parameter then use the following step :
1. First take drive in local mode by pressing LOC/REM button.
2. Press enter button and select PAR and then press enter button & goto the parameter group 99.
3. After enter select parameter 9902 set value 1 and then press enter button to save.
now your drive reset to the factory default.
