F0036 fault in ABB ACS355 drive
The F0036 alarm code on your ABB ACS355 drive indicates an incompatible software fault. This means the drive has detected a version mismatch or incompatibility between the firmware loaded on the drive itself and the software you're trying to use for programming or parameter settings.
  • Loaded software is not compatible with the drive.
