ABB ACS380 drive programming
Optimize your ABB ACS380 drive performance by configuring parameters like motor data, control mode, ramp times, and more. This guide provides a comprehensive overview for efficient setup.
Here is step by step programming of ABB ACS380 drive:
Step 1 – control wiring
Connect all control wiring for start/stop and speed reference. Below image show control wiring of ACS380 drive.
acs380 abb standard image
Step 2 – Power wiring
Connect input power wiring and motor wiring to the drive. Below image show power wiring of ACS380 drive.
abb acs380 drive power wiring image
Step 3 – Parameters
Below list show all parameter used in ACS380 drive programming.
Macro Select
  9604 1 ABB Standard
Motor Data
  9906 ……A
  9907 ……V
  9908 ……Hz
  9909 ……rpm
  9910 ……KW
Control Mode
  9904 0 Vector
    1 Scaler
  9913 0 None
    1 Normal
    2 Reduced
    3 Standstill
    4 Autophasing
    6 Advanced
    8 Adaptive
ACC/DCC Time     For Vector
  2311 0 acc/dec time 1
    1 acc/dcc time 2
    2…..5 DI1……DI4
  2312 ……s Acc time 1
  2313 ……s Dec time 1
  2314 ……s Acc time 2
  2315 ……s Dec time 2
ACC/DEC Time     For Scalar
  2871 0 acc/dec time 1
    1 acc/dec time 2
    2…..5 DI1……DI4
  2872 ……s Acc time 1
  2873 ……s Dcc time 1
  2874 ……s Acc time 2
  2875 ……s Dec time 2
Limits
  3011   Min rpm
  3012   Max rpm
  3013   Min freq
  3014   Max freq
Step 4 – Testing and Verification
  1. Start the Motor: Once programming is complete, you can initiate motor operation using the start/stop buttons on the control panel or through external control signals if configured.
  2. Monitor Performance: Observe the motor's operation and verify it functions as intended. If adjustments are needed, return to parameter setting mode and fine-tune the settings
