Cause : Short circuit comes when short-circuit in motor cable or motor.
The 2340 fault code in your ABB ACS560 drive signifies a short circuit in the IGBT of one of the motor phases. This indicates a serious issue within the drive's internal circuitry or the motor itself.
The "2340 Short Circuit Fault" on an ABB ACS560 drive indicates a short circuit condition detected by the drive. This is a critical fault that requires immediate attention to prevent damage to the drive, motor, and associated equipment.
- Check motor and motor cable for cabling errors.
- Check there are no power factor correction capacitors or surge absorbers in motor cable.
