Cause : IGBT overload comes when the IGBTs in the drive are experiencing excessive current or overheating. . This fault protects the IGBT and can be activated by a short circuit in the motor cable.
The 2381 fault code in your ABB ACS560 drive indicates an IGBT overload. IGBT (Insulated-Gate Bipolar Transistor) is a type of semiconductor device used within the drive's internal circuitry to regulate power flow to the motor. A 2381 fault signifies that these IGBTs are experiencing excessive overload conditions.
- Check motor cable.
- Check ambient conditions.
- Check air flow and fan operation.
- Check heatsink fins for dust pick-up.
- Check motor power against drive power.
