ABB ACS560 Drive
876
Jun 17, 2024 6:04 am
Cause : External temperature 2 comes when measured temperature 2 has exceeded fault limit. This fault or warning indicates that the temperature measured by this sensor has reached a critical level or has exceeded the set limit.
The fault code 4982 in your ABB ACS560 drive indicates an external temperature 2 fault. This means the drive has detected an excessive temperature reading from an external temperature sensor connected to it.
- Check the value of parameter 35.03 Measured temperature 2.
- Check the cooling of the motor (or other equipment whose temperature is being measured).
