5692 fault in abb acs560 drive
Cause : PU board powerfail comes when power unit power supply failure. This means there's an issue with the internal power supply circuit within the drive's power unit.
The fault code 5692 in your ABB ACS560 drive indicates a power unit power supply failure. This signifies a problem with the internal power supply unit within the drive itself.
Check the auxiliary code (format ZZZY YYXX). “YY Y” specifies the affected inverter module (0…C, always 0 for ZCU control units). “XX” specifies the affected power supply
1: Power supply 1,
2: Power supply 2,
3: both supplies.
