ABB ACS560 Drive
590
Jun 18, 2024 5:11 am
Cause : FPGA version incompatible comes when firmware and FPGA versions are incompatible. This means there's a mismatch between the software (firmware) and hardware logic (FPGA) versions running within the drive.
The fault code 6181 in your ABB ACS560 drive indicates a firmware and FPGA version incompatibility. This means there's a mismatch between the software (firmware) and the hardware logic (FPGA) versions within the drive.
- Reboot the control unit (using parameter 96.08 Control board boot) or by cycling power.
