71A3 fault in ABB ACS560 drive
Cause : Mechanical brake opening failed comes when mechanical brake control is faulty. Brake open acknowledgment is not matching the actual status.
The fault code 71A3 in your ABB ACS560 drive indicates a mechanical brake opening failure. This means the drive detected an issue with releasing the mechanical brake on the motor when needed.
  • Check connections, brake settings and brake acknowledgment signal.
