Optimize your ABB ACS560 drive performance by configuring parameters like motor data, control mode, ramp times, and more. This guide provides a comprehensive overview for efficient setup.
Here is step by step programming of ABB ACS560 drive:
Step 1 – control wiring
Connect all control wiring for start/stop and speed reference. Below image show control wiring of ACS560 drive.
Step 2 – Power wiring
Connect input power wiring and motor wiring to the drive. Below image show power wiring of ACS560 drive.
Step 3 – Parameters
Below list show all parameter used in ACS560 drive programming.
Factory Reset | |||
9606 | 34560 | Factory Reset | |
Macro | |||
9604 | 1 | ABB Standard | |
Motor Data | |||
9906 | ……A | Motor Current | |
9907 | ……V | Voltage | |
9908 | ……Hz | Freq | |
9909 | ……rpm | Speed | |
9910 | ……KW | Power | |
Control Mode | |||
9904 | 0 | Vector | |
1 | Scaler | ||
9913 | 0 | None | |
1 | Normal | ||
2 | Reduced | ||
3 | Standstill | ||
6 | Advanced | ||
8 | Adaptive | ||
Acceleration & Deceleration Time |
For Vector | ||
2311 | 0 | acc/dec time 1 | |
1 | acc/dcc time 2 | ||
2…..7 | DI1……DI6 | ||
2312 | ……s | Acc time 1 | |
2313 | ……s | Dcc time 1 | |
2314 | ……s | Acc time 2 | |
2315 | ……s | Dec time 2 | |
For Scaler | ||
2871 | 0 | acc/dec time 1 | |
2872 | ……s | Acc time 1 | |
2873 | ……s | Dcc time 1 | |
2874 | ……s | Acc time 2 | |
2875 | ……s | Dec time 2 | |
Limits | |||
3011 | Min rpm | ||
3012 | Max rpm | ||
3013 | Min freq | ||
3014 | Max freq | ||
3017 | Max output Current |
Step 4 – Testing and Verification
- Start the Motor: Once programming is complete, you can initiate motor operation using the start/stop buttons on the control panel or through external control signals if configured.
- Monitor Performance: Observe the motor's operation and verify it functions as intended. If adjustments are needed, return to parameter setting mode and fine-tune the settings
