ABB ACS580 Drive Programming
Optimize your ABB ACS580 drive performance by configuring parameters like motor data, control mode, ramp times, and more. This guide provides a comprehensive overview for efficient setup.
Here is step by step programming of ABB ACS580 drive:
Step 1 – control wiring
Connect all control wiring for start/stop and speed reference. Below image show control wiring of ACS580 drive.
abb acs580 drive abb standard macro image
Step 2 – Power wiring
Connect input power wiring and motor wiring to the drive. Below image show power wiring of ACS580 drive.
abb acs380 drive power wiring image
Step 3 – Parameters
Below list show all parameter used in ACS580 drive programming.
Factory Reset
  9606 34560 Factory Reset
Macro
  9604 1 ABB Standard
Motor Data
  9906 ……A Motor current
  9907 ……V Motor Voltage
  9908 ……Hz Motor Freq
  9909 ……rpm Motor rpm
  9910 ……KW Motor Power
Control Mode
  9904 0 Vector
    1 Scaler
  9913 0 None
    1 Normal
    2 Reduced
    3 Standstill
    6 Advanced
Acceleration
& Deceleration
Time
  2311 0 acc/dec time 1
    1 acc/dcc time 2
    2…..7 DI1……DI6
  2312 ……s Acc time 1
  2313 ……s Dcc time 1
  2314 ……s Acc time 2
  2315 ……s Dec time 2
Acceleration
& Deceleration
Time
  2871 0 acc/dec time 1
    1 acc/dcc time 2
    2…..7 DI1……DI6
  2872 ……s Acc time 1
  2873 ……s Dcc time 1
  2874 ……s Acc time 2
  2875 ……s Dec time 2
Limits
  3011   Min rpm
  3012   Max rpm
  3013   Min freq
  3014   Max freq
  3017   Max output Current
Step 4 – Testing and Verification
  1. Start the Motor: Once programming is complete, you can initiate motor operation using the start/stop buttons on the control panel or through external control signals if configured.
  2. Monitor Performance: Observe the motor's operation and verify it functions as intended. If adjustments are needed, return to parameter setting mode and fine-tune the settings
