ABB ACS580 Drive
221
Apr 28, 2025 11:12 am
Cause: Overcurrent comes when the drive's output current suddenly exceeds its internal trip limit. The motor is drawing too much current due to a heavy load, mechanical jam, or stall.
abb acs580 fault 2310 indicates an Overcurrent condition. This means the drive detects that the current flowing to the motor or inside the drive has exceeded the permissible limit.
Follow these steps to correct abb acs580 fault 2310:
- Check Motor Load: Reduce the mechanical load on the motor. Inspect for any jams or obstructions.
- Review Acceleration/Deceleration Times: Increase the acceleration and deceleration times.
- Inspect Motor and Cables: Visually check the motor and cables for any signs of damage or incorrect wiring.
- Confirm Motor Parameters: Ensure the parameters in Group 99 accurately reflect the motor's nameplate data.
