ABB ACS800 Drive Programming
Optimize your ABB ACS800 drive performance by configuring parameters like motor data, control mode, ramp times, and more. This guide provides a comprehensive overview for efficient setup.
Here is step by step programming of ABB ACS800 drive:
Step 1 – control wiring
Connect all control wiring for start/stop and speed reference. Below image show control wiring of ACS800 drive.
Step 2 – Power wiring
Connect input power wiring and motor wiring to the drive. Connect input supply to L1, L2 & L3 and connect motor wire at terminal U2, V2 & W2.
Step 3 – Parameters
Below list show all parameter used in ACS800 drive programming.
Macro
  9902 1 ABB Standard
Motor data
  9905 ……V
  9906 …...A
  9907 …...Hz
  9908 …...rpm
  9909 …...KW
Control Mode
  9904 Vector
    Scaler
  9910 1 ID Mag
    2 Standard
    3 Reduced
Linits
  2001 …...rpm Min Speed
  2002 …...rpm Max speed
  2003 …...A Max output current
  2007 …...Hz Min freq
  2008 …...Hz Max freq
ACC/DEC Time
  2202 …...s Acc time 1
  2203 …...s Dec rime 1
  2004 …...s Acc time 2
  2005 …...s Dec time 2
Step 4 – Testing and Verification
  1. Start the Motor: Once programming is complete, you can initiate motor operation using the start/stop buttons on the control panel or through external control signals if configured.
  2. Monitor Performance: Observe the motor's operation and verify it functions as intended. If adjustments are needed, return to parameter setting mode and fine-tune the settings
Click2Electro
Get free chat support...
🟢 Online
