ABB ACS850 Drive Programming
Optimize your ABB ACS850 drive performance by configuring parameters like motor data, control mode, ramp times, and more. This guide provides a comprehensive overview for efficient setup.
Here is step by step programming of ABB ACS850 drive:
Step 1 – control wiring
Connect all control wiring for start/stop and speed reference. Below image show control wiring of ACS850 drive.
abb acs850 abb standard macro image
Step 2 – Power wiring
Connect input power wiring and motor wiring to the drive. Below image show power wiring of ACS850 drive.
abb acs380 drive power wiring image
Step 3 – Parameters
Below list show all parameter used in ACS850 drive programming.
Factory Reset
  1604 2 clear all
Motor Data
  9906 ……A
  9907 ……V
  9908 ……Hz
  9909 ……rpm
  9910 ……KW
Control Mode
  9905 0 DTC
    1 Scaler
  9913 0 no
    1 Normal
    2 Reduced
    3 Standstill
Limit
  2001 ……rpm Max speed
  2002 ……rpm Min speed
  2005 ……A Max output A
Acceleration Time 2202 ……s Acc time 1
Deceleration Time 2203 ……s Dcc time 1
Mot phase loss
  3004 No
    Fault
Brake Chopper
  4801 Disable
    Enable
  4804 ……KW Brake power
  4805 ……ohm Ohm Value
Step 4 – Testing and Verification
  1. Start the Motor: Once programming is complete, you can initiate motor operation using the start/stop buttons on the control panel or through external control signals if configured.
  2. Monitor Performance: Observe the motor's operation and verify it functions as intended. If adjustments are needed, return to parameter setting mode and fine-tune the settings.
