2391 fault in ABB ACS880 drive
Cause: BU current difference comes when AC phase current difference between parallel-connected inverter modules is excessive.
The fault code 2391 in your ABB ACS880 drive indicates a AC current difference issue between parallel-connected inverter modules. This means the DC current flowing through each module isn't balanced.
  1. Check there are no power factor correction capacitors or surge absorbers in motor cable.
  2. Check motor cabling.
