ABB ACS880 Drive
433
Jun 11, 2024 4:39 am
Cause : BU earth leakage comes when total earth leakage of inverter modules is excessive. A 2392 fault in ABB ACS880 drive indicates a potential earth fault, which means current is leaking to the ground instead of flowing through the intended path in the motor circuit.
- Check there are no power factor correction capacitors or surge absorbers in motor cable.
- Measure insulation resistances of motor cables and motor.
