ABB ACS880 Drive
880
Jun 11, 2024 4:42 am
Cause : Earth leakage comes when IGBT supply unit has detected an earth fault. A 2E01 fault code in your ABB ACS800 drive indicates an earth leakage fault. This means current is escaping the intended path in the motor circuit and leaking to the ground.
- Check AC fuses.
- Check for earth leakages.
- Check supply cabling.
- Check power modules.
- Check there are no power factor correction capacitors or surge absorbers in supply cable.
- If no earth fault can be detected, then hardware issue in drive.
