ABB ACS880 Drive
1,124
Jun 14, 2024 11:06 am
Cause : Short circuit comes when IGBT supply unit has detected short circuit. This means an unintended path has formed within the IGBT supply unit, allowing current to flow uncontrollably.Â
A 2E02 fault code in your ABB ACS880 drive indicates an Short circuit fault. This fault signifies the drive's internal control system has detected an issue short circuit in IGBT unit.
- Check supply cable.
- Check there are no power factor correction capacitors or surge absorbers in supply cable.
- After correcting the cause of the fault, reboot the control unit (using parameter 96.8 Control board boot or by cycling power.
