ABB ACS880 Drive
549
Jun 11, 2024 5:13 am
Cause : FPTC not found comes when a thermistor protection module has been activated by parameter 35.30 but cannot be detected.
The fault code 4990 in your ABB ACS880 drive indicates a general external sensor fault. This means the drive has detected an issue with an external sensor connected to it.
- Power down the control unit and make sure that the module is properly inserted in the correct slot.
- The last digit of the auxiliary code identifies the slot.
