ABB ACS880 Drive
847
Jun 15, 2024 5:47 am
Cause : Reduced run comes when number of supply modules detected does not match the value of parameter 195.13 Reduced run mode, or the value of parameter 195.13 Reduced run mode indicates a configuration that is not possible.
- Check that the value of 195.13 Reduced run mode corresponds to the number of supply modules present.
- Check that the modules present are powered from the DC bus and connected by fiber optic cables to the BCU control unit.
