ABB ACS880 Drive
478
Jun 15, 2024 7:39 am
Cause : Charging feedback comes when charging feedback signal missing, incorrect parameter setting or the charging switch and DC switch were operated out of sequence, or a start command was issued before the unit was ready.
- Check the feedback signal coming from the charging system.
- Check the setting of parameter 195.09 Switch fuse controller. Enable the parameter only if an xSFC charging controller is installed.
- The normal power-up sequence is:
1. Close charging switch.
2. After charging finishes (charging OK lamp lights), close DC switch.
3. Open charging switch.
