6E27 fault in ABB ACS880 drive
Cause : Adaptive program comes when error running the adaptive program due to program corrupted or block non-existent, required block input missing or program corrupted or block non-existent.
Check the auxiliary code (format XXXX YYYY). “XXXX” specifies the number of the function block (0000 = generic error). “YYYY” indicates the problem (see actions for each code below).
  • 000A - Program corrupted or block non-existent. Restore the template program or download the program to the supply unit.
  • 000C -  Required block input missing Check the inputs of the block.
  • 000E -  Program corrupted or block non-existent Restore the template program or download the program to the supply unit.
  • 0011 -  Program too large. Remove blocks until the error stops.
  • 0012 -  Program is empty. Correct the program and download it to the supply unit.
  • 001C - A non-existing parameter or block is used in the program. Edit the program to correct the parameter reference, or to use an existing block.
  • 001D - Parameter type invalid for selected pin. Edit the program to correct the parameter reference.
  • 001E - Output to parameter failed because the parameter was write-protected. Check the parameter reference in the program. Check for other sources affecting the target parameter.
