ABB ACS880 Drive
515
Jun 11, 2024 11:58 am
Cause : Mech brake opening failed comes when the drive has detected an issue with releasing the mechanical brake on the motor.
The fault code 71A3 in your ABB ACS880 drive indicates a mechanical brake opening failed issue. This means the drive detected a problem with the system responsible for stopping the motor when needed, which is crucial for safety.
- Check mechanical brake connection.
- Check mechanical brake settings in parameter group 44 Mechanical brake control.
- Check that acknowledgement signal matches actual status of brake.
