ABB ACS880 Drive
482
Jun 12, 2024 6:01 am
Cause : External temperature 2 comes when measured temperature 2 has exceeded warning limit. The fault code A492 in your ABB ACS880 drive indicates an External Temperature 1 Warning. This signifies that the drive has detected a temperature exceeding the pre-defined warning limit for an external temperature sensor connected to input number 2 (Temperature 2).
- Check the value of parameter 35.3 Measured temperature 2.
- Check the cooling of the motor (or other equipment whose temperature is being measured).
- Check the value of 35.23 Temperature 2 warning limit.
